wow it has been 5 years
I pulled the motor out back when I had the oil pressure problem and dropped in a temporary motor, now the temporary motor is needing replaced. since it was worn out when I got it. but this 360 is a good motor and I didn't want to screw it up. I have owned it since it only had 30,000 miles on it. now I need to fix it and get it back in my truck.
I don't have a bore mic, I do have a cheap set of digital calipers.
I will pull the caps off and get pictures, I will mark the caps to make sure I get them back on the right place. probably tomorrow.
thanks
