I'm at 4° down. Nickel width air gap at rest. Bars in bottom hole. Upper shock mount moved to framerail to get them as vertical as possible.
Has been 1.36 60 ft. on a 275 drag radial.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
