I have Aerospace Components front discs, but I'm thinking of using Wilwood for the rear. Does anyone foresee any issues mixing the two? I have the MP master cylinder...can I still use this if I switch to the rear to discs?
Mixing and matching properly sized components from different Mfg' shouldn't be an issue, The key is properly sized components. I have even swapped one MFG caliper on to a different MFG brackets without any issues. The master cylinder dia needs to be sized correctly for teh amount of piston area being installed. You may get lucky with the one you have but more than likely you will need a new (different size) one. Drum brakes require more fluid volume than a disk system.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
