Originally Posted by stumpy
that is why you leave the bolt less the washer in the crank.
or a grade 8 washer on the end of the puller that is larger than the crank bolt hole.
a simple dab of rtv will hold the washer in place, and makes the washer easy to remove when done as well.
beer
