I am running a bg 1000 race also , Its a little strange on idle set up , I start with all 4 corners at 1 turn out , ball out the throttle plates around .025 at transfer slot and allways work my way in around 3/4 on the mix screws, My 1050 holley is 2 turns out and reacts normal ?
