Thanks Tig, that is helpful and definitely indicates at 900 hp and 4000 pounds the stock shafts are questionable.
I think the other option would be to add a gear vendors, since it moves the speedo gear to after the 727 output shaft, but then it's adding even more weight to the car.
'18 Ford Raptor, random motorcycles, 1968 Plymouth Fury III - 11.37 @ 118
