at Idle my IAT get 115-120, but as soon as I get on it they drop to 3 to 5 deg more than ambient, the T/A has a true cold air set up , open top box that seals to the hood scoop, then the left headlight gets air also, Thanks for the update, YES post everything about our late model stuff
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
