Can anyone post some pictures of 1968 Coronet rocker mouldings on here as i dont have any for referance and need to see what they look like ??, thanks Moparts for the free post.
There are two different sizes (widths) that were made and it depends upon the model you have. I also believe (could be wrong) that the thinner ones were fluted rather than smooth.
My 68 R/T takes the wider mouldings.
Here is a picture of the correct front clamp but nobody reproduces them and if you use the one they send in the kits you will have to re-drill the fender to get it to work.
