I'm thinking they are 1/16 I.D., not 1/8 I.D. The 1/4 inch I.D. copper line I used work like a charm, it was enlightening how rapid it would change readings when driving the car or revving the motor up out of gear I was told by a NHRA tech guy later to remove it and put the smaller ling back in that bracket car Looking back I should have used a stainless covered #4 AN line and fittings
