I'd never use steel shim gaskets with aluminum heads but if you have them on there you might as well run them until they cause a problem. You'll have to resurface the heads when you pull it apart. Did you verify that the head gaskets were large enough to clear the combustion chambers? Often times the OEM steel shim gaskets won't clear aftermarket combustion chambers.
