There is some stuff called cutting tape. It's for use with vinyl wraps. It's a fine line tape with a wire imbedded into it. Depending on what you want to do, you could lay out your stripes with that cutting tape. Then put your vinyl down on top. Then simply pull the wire out. I thought about doing that with my Dart. It would be a decent way to lay out some carbon fiber vinyl stripes.
