Wondering if anyone has built a combo out of a 5.7 block (early or late) with the crank and rods from a 6.4? I know the pistons wont work since they are over .170" larger, so wondering if there is an off the shelf piston for this that works? What heads and compression? Power numbers? Wondering what some have done since I know the 6.4 crank is supposed to be quite strong.
Any experience or combos you're willing to share are appreciated.
