What's typical of your .500 Pro Tree RT? I don't have much experience foot-braking from a Pro Tree, which is why I ask.
You can likely jimmy the secondary linkage so that they don't open or only open slightly. Probably need a long link that you can bend to work... or maybe something even cruder like remove the link and zip-tie the secondaries shut?
FWIW, I've been considering trying local 7.50 1/8 and 11.50 1/4 index classes this year in my 1320, although the car is pretty far off the mark, especially in the 1/4. Might have to look into easy weight removal tricks to squeeze what I can out of it.
If I can get the old car dialed in on the track, I expect it would be a better fit in the 6.50 / 10.0 classes than the 1320 will be in the 7.50 / 11.50.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
