Ask KB if they have any feedback. My guess is that you wouldn't need bushings since you have drilled oil galleries. So the lifters are going to be flooded with oil whenever the engine has oil pressure. I suppose it might depend on how big the valve springs are. If you run an Accusump the engine will have oil pressure during cranking so the lifters will always be operating on an oil film.
