The lower torque you are making than the other guy will help lower the stall.
BUT
You are considerably heavier than the other guy with a considerably higher gear. This will raise the stall, likely more than your lack of torque will offset.
Pass on that used convertor.
Something like a TurboAction 17805M would probably be a better bet.
