Restored springs after sandblast, colored with dilute gun blue, since full strength is too black, and coated with RPM wax. Note the second leaf down is the additional leaf, making a total of 7. In this case, the extra leaf was not drilled on the ends for the plastic sliders, but should have been.
Also note new pure zinc interleaves at the center bolt, as original.
If you don't see two dolphins, you need a vacation.
