Wondering what the preferred dolly is. I prefer not to fabricate my own and I've seen the ones that bolt on to the k frame mounting points and the front spring perch location in the rear. I fear this style would be a little tippy as they are so close together. I was considering this one. What do you guys think? Thanks.
https://autotwirler.com/product/elite-body-cart/ I have a set of bolt on ones for sale. I used them on my Duster project and they worked fine. A '71 B body is a bit bigger and heavier so you might want some reinforcements.
