Originally Posted by 6PAX
Originally Posted by SomeCarGuy
Maybe take nut off and tap the arm on a little with a brass hammer? Does it look like it’s in alignment/free movement with the center link?
Yes, it all moves like it should. I had it all centered when I started tightening the nut but the pitman arm turned to full lock (as shown in the pic) while I was tightening it.
Is the bottom of the pitman arm flush with the splined shaft ? How's the angle of the centerlink , does it seem parallel under the pan ?
running up my post count some more .
