OEM ballast resistor isn't hooked up - seems someone used the double unit supplied with the MP electronic distributor kit.
Rear bumper in the close-up shot is definitely too low - hopefully just an adjustment - but oddly looks about normal in other shots.
No mention of #s, looks like an older restoration for the most part, wonder if the 8-track was original or added?
