I haven't taken the valve covers off yet as it winter here and dealing with some health issues but, I wanted to ask before hand. I thought someone might remember if they had something similar. It did have 1.6 rockers prior then they switched to the Crower Rockers and Lifters. If I recall there was guys running the Mopar Magnum ones I think with the Harland Sharp Rockers if I remember correctly. I'm not sure what brand the tall ones on it are now. They came on the truck as you see.
Those cast VCs look to have full length baffles same as stock Magnum VCs. They are 10 bolt but the spacing fits 5 bolt heads, I've wondered if that creates leak issues.
Hope this helps
