Neither column has tilt. Yes, I am replacing the column. The car is being converted from a column-shift automatic to a manual transmission. I didn't want to have a column shifter left over after converting to floor shift.
Ok, understood.
The floor shift column, take a picture of the splined shaft where the Tuff wheel adaptor would bolt on.
