W2’s were produced for quite a few years, and there are a few “generations” of them.
At least one generation is fairly known to be crack prone on the exterior of the head by the outer head bolt holes.
The subsequent generation had vertical “ribs” added to the castings in that area, to specifically address that problem.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
