the real problem with the '933 spring is they get into coil bind rather quickly and are a high rate spring. if you can keep lift in a modest range they are usable. i have some of those springs, and unlikely to use them again. i wouldn't use them on a .509 cam even if the factory says it's ok.. the original springs had a pale yellow strip and the newer version has a green stripe; they're both the same.
