Originally Posted by Devil
That is back from 2019 or so. It's a dealership done conversion.
Does anyone value Dealership conversions a higher value that being converted/cloned in recent times?
Friend owned a SS396 70 1/2 Camaro that had a 454 LS6 installed at the dealer. It happened a month or two after delivery. Motor swap dealer Invoice showed the car with 2,699 miles on it. Had many notes the original owner took that called GM factory rep asking what car to order to make the swap easiest. Owner/Buyer referenced 1970 Hot Rod article saying you could do this swap. I saw the Doc's and car in person for some time for close scrutiny.
Would that Camaro be worth more than 454 LS6 swapped SS 396 car done a year ago?
IMHO, same situation as new 383 car converted to Hemi by dealer with paperwork.
Copy of Dealer Engine Install Invoice BW.jpg1970 Chevy Prod Engine Assemblies Pg 9.jpg
Original owner printouts of available engine assemblies. Note: 3981000 matches invoice.
