Originally Posted by Cuda340
Also a 68 power-loc will have the one piece side gears, the earlier units had two piece side gears and you would have to use the axles to align the splines before tightening the unit back together after a clutch rebuild.
Learned something new , I've only seen 2 piece side gears in the few I have owned , now I have something to look for .
running up my post count some more .
