I am hoping it’s a valve body issue and that just needs a fix and not have to remove and disassemble the trans….
I took it for a quick drive, and geeez it feels so much faster with an an
To than it did with the 4 speed.
Still does the reverse thing.
I tried to see if I could shift it into reverse from any point after going forward, just slowly moving the shifter towards reverse- no luck. It is either forwards or neutral then park. I readjusted the linkage per the hurst instructions and same- no change.
I’ll call cope on Tuesday and see what he thinks may be going on.
