Off the top of my head, the ignition wire at the relay is jut to bypass the ballast resistor when cranking. Unless it shorts out somewhere I don't see it causing a stall situation.
Assuming the problem persists after changing the ECU and coil, I'd be suspect of the pickup coil in the distributor.
