Originally Posted by 52savoy
I had to press the original bearing hub off the shaft. The new parts slide on and rattle around. Haven't measured diameters yet but there is a big difference. Rechecked the pn's and they suppose to be correct.
The new axle should easily slide into the new hub. They are not pressed together. Once the nut is torqued to spec it should be tight. Your old one was most likely rusted together. Detroit Axle is known for selling cheap Chinese junk.
