On the + side - It has a 2.2 or 2.5, two of the best 4-bangers ever made and incredibly reliable. Decent mileage, easy to work on, but not a powerhouse. Cheap, decent transportation.
On the - side - Needs a windshield. The interior wasn't cleaned before pictures taken, so assume no preventive maintenance. Figure a timing belt at the least. The bottom of the front of the rear wheelwell is rotted, so you'd have to get under the car to see how bad the front of the rear suspension is. As in, is it rotted badly.
I'm a little curious about the cut/snapped belt lying on the passenger floor. Belt to the AC?
