Originally Posted by topside
What about changing the fitting on whatever is posing the connection problem ?
I'm making a bypass around the mechanical fuel pump. The pump threads are 3/8npt.
Rethreading one of the -8 connections to 3/8npt seems like the best option so far. It still needs to be mocked up in the car and that may change things.
