2 ways to describe the same thing. In the illustration, rr is toe in, lr is toe out. With a solid axle, total toe doesn't change.
Toe is measured in reference to the other tire on the same axle and the vehicle centerline. If you have a toe issue on a solid axle you have a bent one.
There is a reason they are different terms and they are NOT describing the same thing.
