update; went into the garage last night to test this resistor wire thing, does anyone know what the resistance values should be ? I get the black wire, I tested it ,4 ohms, test the white wire, same thing 4 ohms...... seems to me white wire should have a higher ohms reading, unless I'm testing this wrong. I have one test lead plugged to connector that plugs to the motor and the other lead plugs to the white/black wire connector at the kick panel location where I touch the test lead to one or the other wire. Back to my first post, I totally forgot about that double wire connector at the kick panel..... so I stated that it had (1) wire from the dash to the motor, I was totally wrong (my bad) if I would've spotted the kick panel connector that would've explained the (2) position switch. I guess that's what you get when the car is in parts for 40 plus years.
Later, BUZZ
