I don't think it's a dumb question. But if this helps anymore: if you have a good wedge block, order the wedge pattern Predator heads. Have a hemi block order the hemi bolt-pattern Predators. Like anything else you'll have to clearance things where needed. Often the pushrod area as you can see in other posts here.
