Originally Posted by Neil
Don't those have a roll pin that goes thru the T handle thru the steel shaft? Roll pins come out with a small punch and a hammer.
Make sure the punch is not so big that it gets caught in the hole as the roll pin is being driven out. You can use a nail that is just slightly smaller than the poll pin OD to tap in thru I suppose.
iagree hammer wrench up scope
