I'm not sure what tires I'll run on it. I'd like to use the factory wheels so I'll more than likely stick with 235/60/15s. I want it as a parts chaser and will horse it from time to time. It probably will never see the track. I do have a fresh 727 auto that I will use. Not sure if there is a factory driveshaft for this set up. This is a project that my best friend bought years ago. It sat in his barn for close to 20 years. Last year I built the 360 for him. He passed away a month ago and I got the car. I want to build it the way he wanted it. The shop that did the machine work squared and decked the block. We set it up with good quench, 9.8 to 1 compression. A set of 915 heads, gasket matched and light bowl work. A 72 340 intake for now. I can't find the cam card but the guy I spoke to at Comp Cams said in a 9.0 to 1 and otherwise stock 360, it made 363 hp.
