Originally Posted by Racer33
I'm in the process of building my first car with a motor plate. I want to run an alternator as the car will see some street use. What are you using for an alternator and mount? Was looking at the AR engineering setup but it looks like the Doty crank pulley recommended is no longer available.
I have several NOS Doty crank pulleys holding down a shelf. What one are you looking for ?
1941 Dodge WC, 493 cid twin turbo FAST XFI
2002 Dakota R/T RC
