Originally Posted by toplescuda
At some point. Can I pull the axel. Install green bearing
Install new normal type axels along with normal brakes
Not without some modifications; they changed the bolt pattern at the end of the housing in '65...you can install the later brakes with custom axles and Green bearings but you'll have to re-drill the bolt pattern.
The INTERNET, the MISinformation superhighway
