Electricians are wiring my garage. They are about done but still need to run the wiring for an eventual 4-post lift. Looking on Bendpak's website, the owners manual instructions say to use a 25amp breaker or fuse. Under the FAC they say to use a 30 amp breaker. I'm having it wired for 220v and I'm wondering what wire size to have the electricians run. A 30 amp breaker should require 10gauge wire but the electrician is saying that the pumps don't use nearly that much under normal opperation. He thinks 12 gauge might be fine but wants to know the motors specs.
For those who have a hoist, what size wire are you using? I can't find any other info on the pump motor on Bendpak's website. I'm tempted to just have them run 10 gauge and be done with it.
