Originally Posted by HemiSportFury
Make sure you get your pitman arm situation figured out first. Later PS boxes had a larger diameter shaft and early pitman arms do not fit.This can be a challenge with an early b-body. If it's the smaller shaft you're good.
Any advice on what pitman might work?
