my street car went 9.50 using Harland Sharp. I think with any part you buy you need to check everything. Your cylinder heads are a very critical part. Everything has to work together to include the correct valve spring for the camshaft, locks and retainers, installed height on the springs and one really important item is how the rocker rolls across the valve. T & D has a nice set also. Birdtracker
