Originally Posted by Cab_Burge
The smaller bores, under 1.0 in diameter, stop better than the larger ones over 1.0 inch diameter, way better the smaller you make them up twocents
True. Will make more pressure than the large bores. But the reduced volume may make the amount of pedal travel unacceptable or unsafe.
If the results don't match the theory, change the theory.
