Originally Posted by Jim_Lusk
Upper is the same. Lower is the same casting with 9/16" bolt holes instead of 1/2". All you need to do is drill the holes out.
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes.
Good to know , thanks Jim.
Also good point , if switching to the 73 up large bolt pattern discs the lower is also a different part .
running up my post count some more .
