Originally Posted by gtx6970
It's the outside diameter that's different.
They will not interchange
1969 is larger and is one year only
This , specifically the threaded part that goes thru the hole in the dash is a different size , you can't put a 69 switch into a 68 dash without making the hole in the dash frame , and subsequently the lower dash pad , larger. There is a difference in the wiring also , the 69 has 1 more wire than the 68 ? I've owned both years, parted a few, and played around with the switches at one point.
running up my post count some more .
