Re: cam for my street 440
[Re: donsbelvedere]
#317487
05/13/09 11:57 PM
05/13/09 11:57 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Iam looking at a cam for my 440 that is going into a 1966 Plymouth belvedere that will be a street car.9:1 compression pump gas 452 heads that have been pocket ported,-harlen Sharp- stock style rockers,manley push rods,steel crank,eagle rods,light pistons-30 over,balanced rotating assembly.Speed shop recondmends,Hyderlic cam and here the specs..duration @.050 cam lift int. 224 ext.234...sae duration int. 298 exh. 309....lobe center 107 exh. 117 Gross lift 455 exh. 488...cam lift 310 exh. 325..I want the motor to have good performace and have a nice sound , but be driveable.will this work?will it sound like a 440 that can run?Thanks for the help Donnie
That's a dirty cam...very lazy. I recommend Comps XE275HL. It'll want a tad more converter than stock, like 2500-2600. That cam is 231-237@ .050 with .525 lift on 110lca. I would advance it 5° if you can. It sounds good and pulls hard. Brian
Brian Hafliger
