Re: 8.603 run, data chart, please critique
[Re: fast68plymouth]
#3174211
09/10/23 01:20 PM
09/10/23 01:20 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
After you get done checking things over and making whatever changes you deem necessary......... “What I would do” is prime the system with a drill prior to fire up. Run the motor for as long as necessary to make there are no leaks, etc. After you shut it down.......let it sit at least a day. Then re-prime with a drill and see how long it takes to build pressure. It should be almost instantly. After you get it to where it passes that test, I’d fire it up again, run for a few minutes....shut down let sit for a day again.
Now, prime with accusump...........then re-test with the drill. This test is to insure using the accusump doesn’t back feed the pump prime back thru the hoses/filter and into the pan. You’re looking to see that after using the accusump that there is zero delay in building pressure when running the drill. Thanks Dwayne for the pattern to try. I plan on first looking at the roller lifter on # 6 cylinder, as the lash has opened up .002 or .003. All others were within .0005, and number six rocker assembly checked out good along with the pushrods and adjusters. So my to do list now is check #6 intake roller lifter, pull the oil pump and inspect, and pull the pan and clean that up as well as check the swinging pickup, and check bearings. I need to track down where all that junk in the oil came from .If I am missing anything, let me know, folks!
Entire Thread
gregsdart
08/30/23 12:18 PM
JERICOGTX
08/30/23 01:43 PM
gregsdart
08/30/23 03:29 PM
AndyF
08/30/23 02:12 PM
gregsdart
08/30/23 03:39 PM
dizuster
08/30/23 04:29 PM
Al_Alguire
08/31/23 03:00 PM
fast68plymouth
09/01/23 04:12 PM
Al_Alguire
09/01/23 05:01 PM
EvilB1Dart
09/01/23 09:31 PM
gregsdart
09/02/23 10:32 AM
AndyF
08/31/23 06:55 PM
J_BODY
09/01/23 01:16 PM
AndyF
09/01/23 02:57 PM
gregsdart
09/02/23 10:37 AM
71Demon528
09/02/23 12:13 PM
J_BODY
09/02/23 06:10 PM
AndyF
09/02/23 07:35 PM
J_BODY
09/02/23 09:48 PM
AndyF
09/03/23 12:54 AM
gregsdart
09/03/23 01:15 PM
AndyF
09/03/23 02:48 PM
gregsdart
09/08/23 03:14 PM
fast68plymouth
09/08/23 03:29 PM
gregsdart
09/09/23 12:21 AM
AndyF
09/09/23 01:10 AM
gregsdart
09/09/23 02:08 AM
gregsdart
09/09/23 02:11 AM
AndyF
09/09/23 04:21 AM
gregsdart
09/09/23 10:19 AM
fast68plymouth
09/09/23 06:00 PM
gregsdart
09/10/23 05:20 PM
PLUM BAD
09/10/23 05:52 PM
440Jim
09/08/23 04:12 PM
gregsdart
09/19/23 02:20 PM
moparx
09/19/23 06:04 PM
dvw
09/19/23 07:31 PM
fast68plymouth
09/19/23 08:02 PM
slantzilla
09/20/23 12:42 AM
HardcoreB
09/20/23 11:50 AM
moparacer
09/20/23 01:46 PM
gregsdart
09/20/23 02:11 PM
tboomer
09/20/23 03:44 PM
moparx
09/20/23 08:38 PM
80arrow
09/20/23 09:18 PM
RustyM
09/11/23 07:51 PM
gregsdart
09/13/23 08:32 PM
gregsdart
09/08/23 08:12 PM
hugo
09/01/23 02:29 AM
gregsdart
09/02/23 10:36 AM
