Did you try to resync the cam and crank sensor using a scan tool? I would also check the camshaft tone ring for issues as well, next step would be to verify the wiring from the camshaft sensor and the crankshaft sensor to the pcm wiggling the wiring harness while watching your omh meter.
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
