Sandy - I measured my set up last night and would agree with Doug about the 5 degree offset. I had to eye ball the spring mounts since I was not going to disassemble the springs. I was getting numbers in the 4.6 to 4.8 (ish) range and the axle housing did not have scars from anything cut off and rewelded.
68jim
