As mentioned there could be a lot of different things causing it. First loosen the bearing caps(both main/rod) and see if you can move it. If not then you need start disconnecting piston rods to find where the problem is. When you had the block bored did you give them the pistons? Sometime there are slight machining differences that the machinist needs to take into consideration when boring.
