Thank you gentlemen. I am going to drop them off at a spring shop and get them de arched. I need a total drop of 4 inches. Ill see the max they can safely de arch the springs and then Ill have the option of a 1" or 2" block. If I would have mounted the OEM leaf spring mounts INSIDE the frame I would not have this issue. But inside the frame means relocating the gas tank and I simply didn't want to change something that works well. My truck will have some rake to it it- but currently its way too high.
