Both of these are good options.
I've built a lot of hot rods. The tank vent to the top of the fill tube with a vented cap is my normal go to option, as long as the vent tube is attached to the fill tube above the tank level.
After these two options, the next option would be to vent the tank into a carbon canister and have the fumes sucked into the motor like the modern stuff is. Its a bit more complicated, but if you can't find a vented cap for your fuel fill or a good rollover valve set up. it may be another option.
